0 members (), 160 guests, and 5 robots.
Topics128,149
Posts1,056,818
Members48,456
Now that the crushers are going full blast smashing old iron to send to China, it's time to decide what you want to save fast. There is a one ton gmc in the wrecking yard with what I believe you would call a "brownine over and under" box. It is installed in place of the carrier bearing.
Does anyone here know much about these boxes? I had heard they were pretty neat because of the overdrive and underdrive features for hauling. grin
How many gear positions does it have? Some Brown transmissions have over, direct, and under gears for a total of 3 speeds. If it has 2 shift rods, you've probably got a 3-speed unit there. Grab it, along with the shifter assembly out of the cab! The next trick is learning to shift it, since it's a non-synchronized "crash box" transmission! I learned to drive 18-wheelers on a 5X3 speed setup with two shifters.
I
I Offline
6066.com has ratios for some of the spicer auxillary transmissions that were used by GM. Click on the GMC TRANSMISSION link.
You might also try searching for "Brown-Lipe Bob" on google. He knows a lot about the Brown-Lipe aux trannys and likes to talk about them.
I
I Offline
Below is one of the emails I recieved from Brown-Lipe Bob. Good information.
Steve, the Dana/Spicer units being newer would mean that parts would be somewhat easier to find. As far as the older Brown-lipe units holding up under the higher speeds of today's trucks, I can't really say. I have not heard of any problems from people that I have talked with. One guy was making round trips from Oklahoma to Mexico hauling flowers and he had a lighter 30 series mounted in a **** Diesel and it held up okay. The only comment that I have heard from some people is that the gears whine at higher rpms.
The older Brownies have a flat top on the case which the Spicer unit does not have. The flat top allows the unit to mount higher up next to the body. The Brown-lipe units had the capability of mounting a Power tower on it. The power tower was a top mount PTO that could deliver the full input torque.
I don't have a lot of info on the Spicer units but will help if I can. Keep me posted. Robert.
