1 members (Woodcmiami),
72
Mod | | | Forums66 Topics128,031 Posts1,055,433 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2005 Posts: 34 Junior Member | | Junior Member Joined: Oct 2005 Posts: 34 | I need ball ends for the pitman arm and stearing arm on a 49 chevy 1 ton.
I thought about ordering this from Jim Carters, part #ME6911N. But it says they are 1/2 ton unless otherwise noted, they aren't noted.
Is there a difference? I assume my trucks balls are larger hahaha. but seriously, where can I find replacements.
Frank 1949 Chevy 3800 1929 Chevy International
| | | | | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 | try http://www.stovebolt.com/bboard/cgi-bin//ultimatebb.cgi?ubb=get_topic;f=22;t=003275#000018
Jim & Caroline The highway is for gamblers, better use your good sense." Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
| | | | | Joined: Jun 2005 Posts: 321 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 321 | you could try grumpy's in phoenix. i got a rebuild kit for the drag link on my 50 from him.
don't you just love trucks with bigger balls?!? | | | | | Joined: Aug 2000 Posts: 587 Shop Shark | | Shop Shark Joined: Aug 2000 Posts: 587 | Good news maybe. Unless you have a COE or Dubl-Duti truck, the steering connecting rod is the same for all trucks in 1949. Which tells me the ball size would be the same. This information is per the 1950 Master Parts Catalog.
As for changing them, I found it beyond my ability, and took them to a machine shop who changed all four for $60 for me. | | |
