6 members (moparguy, Otto Skorzeny, 2-Ton, lumbersawyer, DadsFirstPickup, Barry Martak), 149 guests, and 0 robots.
Topics128,126
Posts1,056,354
Members48,441
Hey,I've heard rumors about using everything from molasses to electrolysis to get rid of rust. Does it work? What is the most economical way to get rid of it? Any tips would be great, thanks.
Anonymous
Unregistered
Anonymous
Unregistered
Depends on where your rust is and how far you are willing or able to go. There are very few effective short cuts when dealing with cancer. There are several right ways and many more halfass ways.
If you would describe your problem(s) then we may be able to help more.
there's a good read about the electrolytic thing [pdf download] in the tech tips section - works great and pretty cheap - sheet metal body panels are best done w/ sanding or careful blasting
If it's relatively small and has only surface rust; I've had good succes with vinegar soaks.
Steve G.
1942 Chevrolet 1/2-Ton Pickup Truck
I use a Permatex product called "Rust Treatment"
(RT-16A). You just remove the loose material, then paint this stuff on. It turns black as it dries and seems to stop the oxidation process. Leaves a nice hard, paintable surface.
http://www.permatex.com/products/industrial_individual_products2.asp?selectid=30&category=maintenance&oe_category=engine&product=Permatex,+Rust+Treatment
You never have enough, til you have too many!
I think there are really only two ways to get rid of rust. You can isolate it so it can not get any air, no air, no more rust, or you can cut it out and replace the metal. If it is just surface rust, I've had good luck with plain old Rustoleum paint. I get all the loose rust off and sand or grind it down to where everything is solid and tight and paint over it. It seems to work well. I like the brushable kind better than the spray on type, because it seems to me it has more solids in it, however I use the spray when I have a place that is hard to reach. I only use the Rustoleum on places that are not visible, or will not be painted with the regular auto paint, like the frame, under fenders, etc. I have a friend who is a painter,and he is very strict about sealing all seams and joints from the back with either brushable sealer, or the kind you use with a caulking gun. This is to keep out water and air. Most rust comes from the back side of the metal, where you don't see it until one day you are cleaning the truck, and poke a hole in a rocker or something else. Allen
