1 members (edgardo), 79 guests, and 3 robots.
Topics128,057
Posts1,055,808
#194511 11/28/2005 3:44 PM
46 chevy 1/2 ton
After replacing my master cylinder,one of my brake lines, bleeding the brakes and adjusting, I am still running into adjustment problems. It seems now the back brakes are catching more than the front. I am think of just redoing the hole works, Jim Carter has a full rebuild kit for this but am not sure if it is worth it. I am planning on going as original as possible but the brakes are pulling me in different directions, Should I overhaul what I have or should I upgrade to power brakes? Any words of wisdom would be great. Also sorry for any mis-spelled words :rolleyes:
Thanks in advance
Ed
#194513 11/28/2005 5:32 PM
Let me add, especially if those brake lines are original, you NEED to replace them all. It was amazing how thin and fragile my lines were when I pulled them off.
#194514 11/28/2005 6:02 PM
I had one of the lines fall apart when I replaced the master cylinder, I decided the when I do whatever I am going to do the lines will be replaced also.
Ed
