2 members (blanch53, Materman),
111
Mod | | | Forums66 Topics128,072 Posts1,055,906 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2005 Posts: 88 Member | | Member Joined: Nov 2005 Posts: 88 | Could 54' front fenders be used on the 47-53 trucks if you were to fill up the holes? Is the only difference between the two just a matter of holes? The reason I'm asking is because I know where a 54 is at that has some decent front fenders and I'd like to put them on my 52'. Any help would be greatly appreciated. | | | | | Joined: Apr 2001 Posts: 439 Shop Shark | | Shop Shark Joined: Apr 2001 Posts: 439 | I beleive there is a flat spot on the fender. Heres a link to a picture of one. 54 Fender | | | | | Joined: Nov 2005 Posts: 88 Member | | Member Joined: Nov 2005 Posts: 88 | | | | | | Joined: Jan 2005 Posts: 1,682 Extreme Gabster | | Extreme Gabster Joined: Jan 2005 Posts: 1,682 | There was somebody on here a few days ago with a '47-'53 who was confused as to why one of his fenders had a flat spot with some holes in it.. it turned out a previous owner had stuck a '54 fender on it.
So i'd say yea.. if you don't mind doing a little body work to patch the holes, it outta work.
| | | | | Joined: Nov 2005 Posts: 88 Member | | Member Joined: Nov 2005 Posts: 88 | Eureka, it just might work! | | | | | Joined: Oct 2005 Posts: 275 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 275 | I think in the front top corner were the grill bolts up to the fender on the 54 is round were as 47-53 is square so if your using a chevy grill it won't bolt in properly.
38 original 48 panel 59 stepside 46 in the back forty
| | | | | Joined: Oct 2005 Posts: 4,252 "Hey! I sound like Darth Vader!! | | "Hey! I sound like Darth Vader!! Joined: Oct 2005 Posts: 4,252 | Plus, trying to hammer out the flat area would be a pain! | | |
