6 members (Hotrod Lincoln, klhansen, Mike B, Otto Skorzeny, IHPWR, Jims46), 50 guests, and 2 robots.
Topics128,030
Posts1,055,423
Members48,422
#194147 11/23/2005 2:46 AM
Could 54' front fenders be used on the 47-53 trucks if you were to fill up the holes? Is the only difference between the two just a matter of holes? The reason I'm asking is because I know where a 54 is at that has some decent front fenders and I'd like to put them on my 52'. Any help would be greatly appreciated.
#194148 11/23/2005 4:39 AM
I beleive there is a flat spot on the fender. Heres a link to a picture of one. 54 Fender
#194149 11/23/2005 5:55 AM
Thank you, i see it now.
#194150 11/23/2005 6:13 AM
There was somebody on here a few days ago with a '47-'53 who was confused as to why one of his fenders had a flat spot with some holes in it.. it turned out a previous owner had stuck a '54 fender on it.
So i'd say yea.. if you don't mind doing a little body work to patch the holes, it outta work.
#194151 11/23/2005 6:22 AM
Eureka, it just might work!
#194152 11/23/2005 7:35 AM
I think in the front top corner were the grill bolts up to the fender on the 54 is round were as 47-53 is square so if your using a chevy grill it won't bolt in properly.
38 original
48 panel
59 stepside
46 in the back forty
#194153 11/23/2005 10:27 AM
Plus, trying to hammer out the flat area would be a pain!
