7 members (DavidBraley, Otto Skorzeny, J Lucas, 66flea, Rosco, 55shaker, 1 invisible),
122
Mod | | | Forums66 Topics128,283 Posts1,058,504 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#19377 05/18/2004 12:38 AM | Joined: Apr 2004 Posts: 12 Junior Member | | Junior Member Joined: Apr 2004 Posts: 12 | The old 1 pot master cyl. we have is dying a slow death. I've been told that we can replace it with several different updated 2 pot ones, but don't know what to look for. I've seen some in the classic parts suppliers books, but you have to buy the master cyl. and then a adapter kit ($150.00 plus frt.). Is there anything a cheap way out? I want to keep the same peddle.
Ryan
#19378 05/18/2004 2:14 AM | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | My '55 1st now has a '73 Chevelle master cylinder using the Chevy Duty adapter, which looks like its the same kit as the cheaper Classic Performance Products adapter.
If you upgrade to a dual master you need to be ready to also change the brake lines to separate the front brakes from the rear.
If you look at your current master it has two lines coming off of it. One line feeds ONLY the left front. The other line feeds the right front and both rears. With a dual master that won't work.
I replumbed mine completely because at the same time I put disk brakes on the front. Bought 25 feet of line and some tools, and it took an entire day to cut, bend and run the lines.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | |
