5 members (ShopRag, Pinetree, dt235sd, klhansen, Southerntruck), 85 guests, and 4 robots.
Topics128,263
Posts1,058,133
Members48,482
The floorboards are pretty rusted out in my 52 pickup, does anybody have any recommendations as to who makes the best replacement parts, I've seen at least 2 different styles. Next, do you think I need to remove the cab to do this job properly. If so, do I need to make some sort of jig to hold it when I cut the floorboards out. I'm also thinking about doing the Patricks rearend gear change, any thoughts on that mod? I have a 4-speed in the truck now. Dave
1941 Chevy
"First rebuild - complete!"
Follow the story in the DITY
1941 GMC resting peacefully
1946/1947 Chevy Street rod on s10 frame complete
1945 GMC panel truck in line for restoration
1941 Plymouth stock complete
1941 GMC COE in restoration process
Read his Project Journal
1941 Chevy Coe uncertain future resting now
The rearend gear change will cost you about $700 in parts, then you need to install them for a gear ratio of 3 55.
Another option is a T-5 out of an S-10 along with a rear out of an S-10 4X4 or mid 70's camaro, firebird cutlass etc. Weld new spring perches on to fit your truck. My T-5 is still on the garage floor. The truck it was in cost me $100. I don't know how much the Buffalo Enterprises tranny adaptor is to make the t-5 fit my 216...By the time you buy the tranny adapter parts, tranny, rear end and have the rear end welded up, you might be sorta close to paying for PAtricks 3 55 gear set. My problem is I have never rebuilt a rearend. I pay $700 and still might wind up paying another major chunk of cash to get it all installed.
Do a search on this topic with T-5 as keyword if you want more info on a T-5. Numerous owners on here have done it with great results.
Welcome to the Stovebolt page...
