1 members (5 Window 9434), 68 guests, and 2 robots.
Topics128,030
Posts1,055,428
Members48,422
#192150 10/26/2005 1:55 AM
Junior Member
Junior Member
Hi;
My 1954 half ton driver's side door handle points down and moves forward to open the door. The pasenger side handle points down too, but moves back to open the door. That right? It seems unnatural to move the handle forward to open the door. My manual shows the handle pointing down and also says to pull it back to open the door. I'm confused, but that's normal for me.
Rich
I don't see how it could happen but something must have been re-installed upside down. The latch releasing chilibob needs to be pulled forward to un-latch and normally pulling the handle aft pulls the chilibob forward.
I wrote in another thread that my driver's door won't stay locked, but will stay in the unlatched position. Upon closer inspection, turns out the truck has two right-hand latch regulators, one in each door. That may cause your problem as well.
