| | | Forums66 Topics128,042 Posts1,055,519 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2005 Posts: 4 Junior Member | | Junior Member Joined: Jul 2005 Posts: 4 | Anyone know of a good A/C system for a 52'. Recently I have been looking at heat/cool/defost units from Vintage Air and Classic Auto Air. I don't want to go spendin one grand on an A/C system when I'm not sure how well it performs. I don't really need a underdash vent system that fits the stock contour of the dash because I'm going to make my own underdash panel. Any suggestions would be appreciated.
Thanks, bullnose | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | I put the vintage-air heat-cool-defrost unit in my 70. I,m not real pleased with it. If you use the air one day & the next day turn on the heat it fogs everything up. You better have a towel handy because you are blind. One of the controls broke before I got done installing it. They sent a new part but it set the project back a few days. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Sep 2003 Posts: 324 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 324 | I used a Old Air system in my 53 and it seems to work good. The problem is when I get on the highway it seems to fade a bit due to the truck leaks so much air. I think if you want to get any system to work properly the truck needs to be insulated and some what air tight. | | | | | Joined: May 2001 Posts: 477 Shop Shark | | Shop Shark Joined: May 2001 Posts: 477 | and that would be true. another factor is cleaning the evaporator coils by at least blowing them out. lots of aftermarket suppliers make weatherstrip for bolts. if you insulate the inside of the doors make sure you don't trap moisture in the bottom of the doors. i don't think you will like the result if you don't. | | |
