0 members (), 170 guests, and 3 robots.
Topics128,081
Posts1,056,078
Members48,434
#191841 10/21/2005 11:48 PM
Junior Member
Junior Member
I'm trying to locate some info on how, parts availability, etc. on changing my 64 GMC stepside over from single speed wipers to 2 speed wipers. I'm thinking that all that is needed is a switch, motor and the wiring between the 2 units. What have people used for doing this or what other vehicles came with the 2 speed wiper set up that I can get off of?
#191842 10/22/2005 12:32 AM
All 66 had 2 speed(fed regs), you need the motor(same til 72), switch, & small harness w/two extra wires. Get a rebuilt motor from Advance, tell them 2 spd & trade in your single(they can't tell the diff)as a core. I have sold the extra setup I had, but there is a yard locally that has more I'm sure. I added 2 spd wipers to both my 64's, you can get washers also w/this upgrade. Brian
My \'64\'s in the Gallery
Pictures in my Photobucket
1964 C10 Custom Cab 350/700R4
1964 Suburban 350/700R4
1979 Ford F350 4x4 400/c6
#191843 10/22/2005 4:52 AM
Junior Member
Junior Member
sent you a pm
#191844 10/22/2005 5:40 AM
Does that apply for adding 2 speed wipers to my '62? Seems like a lot of stuff changed after '62.
Speed
1954 GMC 350
1957 GMC 1/2 ton
1962 Chevy C-30
'98 Harley FLSTC
'66 Pontiac Catalina
'76 Chevy 1 ton Duallie
'84 Bronco II
'78 Dodge W-200
'81 Toyota 4X4 truck
#191845 10/22/2005 6:05 AM
I think its pretty standard as they were option all years 60-66, but I have seen a '60 that used a diff style motor, not sure if it mounted the same or not. The 2 speed seems to give you too slow or too fast. smile Switches seem hardest to find. Brian
