| | | Forums66 Topics128,083 Posts1,056,080 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2005 Posts: 5 Junior Member | | Junior Member Joined: Sep 2005 Posts: 5 | I'm trying to locate some info on how, parts availability, etc. on changing my 64 GMC stepside over from single speed wipers to 2 speed wipers. I'm thinking that all that is needed is a switch, motor and the wiring between the 2 units. What have people used for doing this or what other vehicles came with the 2 speed wiper set up that I can get off of? | | | | | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | All 66 had 2 speed(fed regs), you need the motor(same til 72), switch, & small harness w/two extra wires. Get a rebuilt motor from Advance, tell them 2 spd & trade in your single(they can't tell the diff)as a core. I have sold the extra setup I had, but there is a yard locally that has more I'm sure. I added 2 spd wipers to both my 64's, you can get washers also w/this upgrade. Brian | | | | | Joined: Sep 2005 Posts: 5 Junior Member | | Junior Member Joined: Sep 2005 Posts: 5 | | | | | | Joined: Apr 2005 Posts: 926 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 926 | Does that apply for adding 2 speed wipers to my '62? Seems like a lot of stuff changed after '62. Speed | | | | | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | I think its pretty standard as they were option all years 60-66, but I have seen a '60 that used a diff style motor, not sure if it mounted the same or not. The 2 speed seems to give you too slow or too fast.  Switches seem hardest to find. Brian | | |
