0 members (), 139 guests, and 7 robots.
Topics128,077
Posts1,056,033
Members48,433
#191747 10/20/2005 1:23 PM
1 Offline
It is a dually, is stamped as "8,800 GVW". Is it worth much? Had Hydromatic from factory, is now 4 speed shifter, and has a Chevy 350 small block with a 4 barrel carb.
He is asking $2,500. It has some rust in the door jam on the front, not sure how to repair.
#191748 10/20/2005 1:53 PM
that would be a 1ton - if it's a decent runnin, drivin truck and you've got a use for one like it, might be worth that, but more than I'd pay - if it needs much mechanical work, like brakes, steering, engine rebuild, it's way overpriced IMO
w/ the usual rotten hinge pockets, there'll likely be other rotten spots - rear cab corners, floor area at front cab mounts, lower rear of fenders, headlight brows, bottom of doors - if you have some welding skill [or can afford to hire it done] the rust is fixable, and patch panels are available for all those places
