3 members (stlcardinalsguy, dunfire, Otto Skorzeny), 110 guests, and 1 robot.
Topics128,136
Posts1,056,427
Members48,441
#191692 10/19/2005 9:08 PM
Junior Member
Junior Member
I'm building a '52-( ½ ton 5 window Chevy)and would like to use a '47-48 fuel tank that mounts on the frame. Unfortunately, my search for such tanks has yielded nothing but exhaustion. Street rodders want to sell me a 400 dollar generic pro street version which will occupy my spare tire space.
Any ideas where I might be able to spot a decent one I can have cleaned/dipped with the original support straps and hardware?
Amir Ebrahimzadeh
#191693 10/19/2005 9:18 PM
I believe there was one For Sale, in the, Parts For Sale Section of, www.oldgmctrucks.com .You have to get there through, the discussion board.It is listed as being for a panel, or suburban, but the seller notes, it is the same, for the '47-'48 pickup.
Spanky Hardy
More pictures on Photobucket
1950 GMC 250 1-Ton
#191694 10/20/2005 8:58 PM
Junior Member
Junior Member
Thanks Spanky. I'll check it out.
Amir Ebrahimzadeh
#191695 10/22/2005 7:25 AM
52A
I used my stock filler tube out of the cab and turned it so it will fit as the filler in front of the pass rear fender. The 1 1/2'' then flares to 2'' and connects to the tank under the passenger side between the rails, in front of the rear axle and tucked up into the frame. Yes I cut the diagonal reinforcing sheet piece. It's 10''x11''x34''. holds 16 gallons.
universal gas tank @ ::
http://www.chassisengineeringinc.com/page86.html
http://discountgastanks.com/?session=ad03defaf3f02a84dfe450ed7a354dce
Gooday
Jim
small wheel moves by fire and rod,
big wheel fires by the grace of god,
everytime that wheel turns round,
bound to cover just a little more ground.
#191696 10/24/2005 7:07 PM
Junior Member
Junior Member
Thanks Jim. I wish I had ½ ya'lls knowledge about these monsters. Have a wonderful day sir.
Amir Ebrahimzadeh
