5 members (Jack Ryan, Bill Hanlon, Mike Roache, KEVINSKI, fonz8261), 127 guests, and 2 robots.
Topics128,089
Posts1,056,418
Members48,443
#19165 01/13/2005 3:07 AM
Junior Member
Junior Member
I have a 66 C20 that had the 250 6 banger in it and the SM420 tranny originally. I am looking to keep the 4 speed but am looking @ getting a V-8 under the hood.
I was told by one person that everything would bolt right up??
I did a couple measurements....the flywheel on the 6-cylinder engine and on the clutch plate the holes were 12.5" accross.
On the 350 engine it measured 11" accross.
Do I need a different clutch plate? I'm probably just over-looking something?
Thanks a bunch for any help.
#19166 01/13/2005 6:25 AM
Flywheels and flexplates are usually referred to by the number of teeth they have on the ring gear: 153 or 168. The diameters are approximately 12 and 13 inches, respectively. It sounds like you have a I6/SM-420 combo with a 168 tooth flyfheel and matching clutch...and a 350 with a 153 tooth flywheel...and a matching starter.
So something's gonna have to change. If you want to keep the larger flywheel (and you're gonna use the I6 bellhousing), then all you'd need to do is get a starter for a 168 tooth flywheel.
If you want to do it the other way around (keep the 153 tooth flywheel and starter), you'd need to get a smaller clutch and pressure plate.
I went thru this when converting a Chevy II from automatic to 4-speed. It was a pita, but eventually you can get all the right parts in there at the same time and it'll work.
#19167 01/13/2005 4:03 PM
The 250 flywheel will work on a small block, except 400. Bolt in deal, you will need a ball stud for the clutch. Brian
My \'64\'s in the Gallery
Pictures in my Photobucket
1964 C10 Custom Cab 350/700R4
1964 Suburban 350/700R4
1979 Ford F350 4x4 400/c6
#19168 01/13/2005 9:53 PM
Junior Member
Junior Member
Hey thanks a bunch fella's.
