0 members (), 48 guests, and 2 robots.
Topics128,094
Posts1,056,066
Members48,433
#19140 02/08/2005 1:40 AM
The engine in my '65 is a 400sbc bored .030 and a high performance cam with Edelbrock manifold and 600cfm carb. It is bolted to a th400 and a 3:73 rear. Today I took it for a test and the water pump snapped at the bearing and the fan went out to lunch with the radiator for it's main course. I was using a 7 blade fan and a fan clutch. I think the weight of the fan and clutch was just too much for the quick torque. With this kind of power, would it be best to use a fan with the alum. blades that will twist under power and do without the fan clutch? I really didn't care for the noise it made when parts started flying. Anyone have any thoughts?
Truck Tinker
#19141 02/08/2005 2:19 PM
I run 7-blade fans and hydrostatic clutches on several cars, including a 375 hp 406. No problems at all.
I don't recommend flex fans. They're noisy, they don't cool well and they have a habit of failing catastrophically....like throwing blades thru the hood.
I'd think that the failure you had was a fluke. An imbalanced fan or a faulty clutch. Btw, when the clutches go bad, they can lock up and run all the time. That's real noisy and could weaken the fan if run for a long period of time that way.
I really don't have any problems with the 7-blade and hydrostatic clutches. I put one on my 292 to replace the solid mount and it's workin fine.
#19142 02/08/2005 3:41 PM
I had a buddy w/a 64 & sm blk 400 back in high school, snapped pumps left & right. His record was 13 water pumps in less than a year. 3.73s & a heavy foot was the cause. He finally went to a lightweight aftermarket plastic fan, no more trouble. I would go electric, we just did on my bro's truck, its unbelievable the revs it freed up by removing the fan. Brian
My \'64\'s in the Gallery
Pictures in my Photobucket
1964 C10 Custom Cab 350/700R4
1964 Suburban 350/700R4
1979 Ford F350 4x4 400/c6
#19143 02/08/2005 11:54 PM
Riding in the Passing Lane
If you use a hydro fan clutch you need an original equipment one. The after markets aren,t any good. smile
1972 Chevy c10 Cheyenne Super
#19144 02/09/2005 3:34 AM
Thanks, everyone. I am really tempted to go electric. Seems like a lot of people rodding go that route.
Truck Tinker
