Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
3 members (Otto Skorzeny, 55shaker, Ribside), 128 guests, and 5 robots.
Topics128,281
Posts1,058,478
Members48,490
#191343 10/13/2005 9:41 PM
I am considering upgrading my stock rear end to be able to cruise at freeway speeds and increase gas mileage. I am thinking about a 3.38:1 ring and pinion gear set in addition to a new installation kit for it. Is there one out there (a different ratio)that might be better suited for what I'm trying to accomplish? What is the best source out there (price and quality)? What has been your experience with a gear ratio upgrade? Thanks in advance for your input.
#191344 10/13/2005 9:57 PM
I went with Patrick's 3:55 gear set and it worked our just fine. Is this assuming you are keeping an enclosed driveline? If so, I didn't know anyone made 3:38 gears for our AD's. Then again, I have been a little out of touch for awhile.
Craig
#191345 10/13/2005 10:18 PM
Mine be a Task Force ('56). Driveline will remain stock on it.
By the way, nice looking truck you have there! grin
#191346 10/13/2005 10:42 PM
Try Chevy duty. They have a 3.38 kit.
#191347 10/14/2005 10:33 PM
Riding in the Passing Lane
I,ve put the 3.38 in & used the install kit. Just the right ratio for those trucks. You still have the original axle that way without doing a lot of modification. It comes with good insructions. I can,t say how hard it is because i,ve been rebuilding them for 50 years. You know if you need help there are plenty of fellow stovebolters here to help.
1972 Chevy c10 Cheyenne Super
#191348 10/15/2005 11:07 AM
Thanks to all for the great advice. Think the 3.38 is the way to go!
#191349 10/16/2005 5:42 AM
So we're talking about a gear swap in the rear?
#191350 10/16/2005 2:29 PM
I want to do a gear swap in my 54 GMC to improve highway speeds and gas milage as well, but I read some where that there are not kits available for the GMC rear end. Is this true? Also is there an easy way to ID what rear end is in my truck? The PO had already switched the Engine to a 261 and the hydramatic to a SM420, so he may have changed the rear end as well.
1954 GMC 1/2-ton Longbed
1971 Pontiac LeMans Sport
#191351 10/16/2005 6:31 PM
GMC axles should be the same as Chebby.
1954 GMC De Luxe COE
#191352 10/27/2005 4:11 PM
Junior Member
Junior Member
I have a 54 GMC 100 and in these hills, my 3.55 may be better than the 3.18..
