1 members (Otto Skorzeny), 115 guests, and 0 robots.
Topics128,049
Posts1,055,549
Members48,425
#191244 12/21/2006 1:17 AM
The 53 never lets me get bored. Today I got the engine to turn completely over but is a little stiff. Good sign. But the oil had some booger stuff in it and a little water. Not good.
So, I went out and looked at the truck. I have the box and front fenders off. On the rear axle one side had a plate on top. Only one side. I looked in the 47-54 assembly manual and saw nothing of the sort. What is it? Should there have been these plates on both side? And were there springs on top of them? The springs are mounted on the bottom of the axle like it shows in the book.
TIA
Dennis
#191245 12/21/2006 1:27 AM
sure wish we had some pix..............dont cha hate that response grin I am trying to remember what mine looked like before removing the old rear end and having the blazer one put in.... I thought I remember plates but not sure.. I know.. big help..
good luck with it though
Redryder pix
My Hotrod
#191246 12/21/2006 5:52 AM
Don't know what the "plate" was for, but there
is a bracket on the passenger side that is used
to mount the brake line "t" fitting. The brake
line hose connects at this point.
Hope this helps. lol
#191247 12/21/2006 6:56 AM
Apprentice
Apprentice
1 Offline
does this pic show the part?
[img]http://i22.photobucket.com/albums/b350/stevehsd/truck013.jpg[/img]
that plate may be for the overload springs
just a guess?
#191248 12/21/2006 10:22 AM
Some sludge in the sump is normal if the engine was using non-detergent oil.
A small amount of water is also nothing to worry about, as condensation will have settled in the sump over the time that the truck's been sitting idle.
But once it's back in regular use,water shouldn't be evident in the oil - something's wrong if that is the case.
#191249 12/26/2006 5:29 PM
1951 chevy truck - thanks for the picture.
The plate that I spoke of looks like it holds the springs (helper springs?) on the top of axle.
Are these helper springs important?
Dennis
