0 members (),
107
Mod | | | Forums66 Topics128,265 Posts1,058,365 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#19098 09/01/2002 4:14 AM | Joined: Aug 2002 Posts: 1 Junior Member | | Junior Member Joined: Aug 2002 Posts: 1 | I am currently upgrading my 64 C-10 to front disk brakes. Will a 1991 Booster w/ master cylinder and proportionate valve work? It came off of a 1991 full size Chevy truck. I have looked at a '72 booster and I can't tell the difference between the '72 and the '90 except the '90 has antilock valve that I would take off. Thanks for the help. Snowdevil | | |
#19099 09/01/2002 4:33 AM | Joined: Nov 2001 Posts: 72 Member | | Member Joined: Nov 2001 Posts: 72 | The newer one probably has metric fittings. What kind of disks are you putting on. Use the same type of fittings, probably standard, to fit with your rears. Adapting these things are a Bit**. Dennis | | |
