| | | Forums66 Topics128,094 Posts1,056,048 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2005 Posts: 1,682 Extreme Gabster | | Extreme Gabster Joined: Jan 2005 Posts: 1,682 | I'm still tinkering with trying to get the 216 in the '46 2 ton running, but wanted to do a little checking to see what my replacement engine options are.
This truck isn't going to be a show truck or a trailer queen.. i'm not going for the 100% resto or the Hot Rod route.. just going to use it to tool around the farm and go into town with.. to that end, I just want a solid, reliable motor.
Other than another 216, or a full pressure 235, are there any other "direct replacement" motors that are a drop in, bolt up fit?
I don't want to hassle with swapping out rear ends or trying to re-route steering columns.
So what'll bolt in a 1946 1/2 ton with a stock 4 speed tranny and rear end?
| | | | | Joined: Jul 2005 Posts: 1,158 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 1,158 | I think that a 261 will fit, but I'm not 100% positive. I've only got 216 and 235 engines to play with. | | |
