4 members (Southerntruck, Samantha, TUTS 59, tclederman), 106 guests, and 3 robots.
Topics128,036
Posts1,055,458
Members48,422
#190678 10/03/2005 12:24 PM
I am replacing my king pins. Should the bushings in the knuckle be a press fit or a slip fit? Mine are a slip fit.
Thanks in advance
Always get a 2nd opinion, especially if I am the source of the 1st opinion.
#190679 10/03/2005 12:32 PM
Slip fit.
1954 GMC 1/2-ton Longbed
1971 Pontiac LeMans Sport
#190680 10/03/2005 12:49 PM
Good. Now I have a dumb questions. I understand that the kingpin has a slip fit in the bushing,but if the bushing has a slip fit in the knuckle what keeps the bushing from turning when I turn the steerin knuckle? Thanks again.
#190681 10/03/2005 1:22 PM
A turning bushing is the desired result. Be sure to stake the end caps good so you won't lose them and the bushings.
Mike Barnes
1950 GMC 1-ton pickup
