0 members (),
40
Mod | | | Forums66 Topics128,030 Posts1,055,428 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2005 Posts: 311 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 311 | I am replacing my king pins. Should the bushings in the knuckle be a press fit or a slip fit? Mine are a slip fit. Thanks in advance
Always get a 2nd opinion, especially if I am the source of the 1st opinion.
| | | | | Joined: Sep 2003 Posts: 343 Member | | Member Joined: Sep 2003 Posts: 343 |
1954 GMC 1/2-ton Longbed 1971 Pontiac LeMans Sport
| | | | | Joined: Mar 2005 Posts: 311 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 311 | Good. Now I have a dumb questions. I understand that the kingpin has a slip fit in the bushing,but if the bushing has a slip fit in the knuckle what keeps the bushing from turning when I turn the steerin knuckle? Thanks again.
| | | | | Joined: Mar 2005 Posts: 627 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 627 | A turning bushing is the desired result. Be sure to stake the end caps good so you won't lose them and the bushings.
Mike Barnes 1950 GMC 1-ton pickup
