| | | Forums66 Topics128,127 Posts1,056,357 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2005 Posts: 1,682 Extreme Gabster | | Extreme Gabster Joined: Jan 2005 Posts: 1,682 | I got compression.. I got the spark plugs sparkin'.. I got a hot wire going from the hot side of the battery to the positive terminal of the coil.. I got the points set... i know my coil, points, cap, rotor and condenser are good because they were pulled from a perfectly running engine..
I dump some gas in the carb... crank it.. no pop.
Timing perhaps?
| | | | | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | Probably is timing, or spark plugs that are fouled. Do you have the right firing order? 153624 clockwise on the distributor.
Paint & Body Shop moderator A lone amateur built the Ark. A large group of professionals built the Titanic. | | | | | Joined: Jan 2005 Posts: 1,682 Extreme Gabster | | Extreme Gabster Joined: Jan 2005 Posts: 1,682 | It's got brandy spankin' new plugs in it (gapped to .037).. firing order is set the same way as it was on the 235 I "borrowed" the cap and wires from. (I assumed the 216 and 235 have the same firing order)
| | | | | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | does it turn over as fast as it should? it does sound like it might be timing,,did this just happen all at once or has some-one been tinkering with it? Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | | | | Joined: Jan 2005 Posts: 1,682 Extreme Gabster | | Extreme Gabster Joined: Jan 2005 Posts: 1,682 | I haven't ever had it running.. it arrived as a "I dunno" motor.
| | | | | Joined: Mar 2005 Posts: 1,029 Member | | Member Joined: Mar 2005 Posts: 1,029 | Distributors are not always installed the same way, number one could be anywhere. Pull the cap and see where the rotor is pointing when the timing mark is in the window. That will be either the position for #1 wire or for #6 wire, depending on which is at the end of its compression stroke. | | | | | Joined: Apr 2004 Posts: 703 Shop Shark | | Shop Shark Joined: Apr 2004 Posts: 703 | Fumblin, I'm going to assume you have spark between the points.
I went through the same thing, 3 different times, when I put the new 216 in my 46. It had been sitting in storage for about 3 years.
I never did determine what the cause was for sure, but I played around with the cap, plugs, roter, coil, and all of the various wires with no success. I eventually filed the surface of the points real lightly, and it popped right off.
It's been starting and running fine all summer since.
By the way, I had spark at the points prior to this, but not as large as I thought it should be. About knocked my father-in-law on his butt, after I filed them. | | | | | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | I dunno what is wrong with it  Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | | | | Joined: Aug 2005 Posts: 43 Junior Member | | Junior Member Joined: Aug 2005 Posts: 43 | Hi; When I bought my truck I had the same situation. Turns out the timing was 180 degrees off. No idea how that happened. Anyway, the rotor should point at the number one plug inside the cap when the timing mark is at TDC and both valves are closed on number one cylinder. You have to pull the valve cover to check this. Rich | | | | | Joined: Apr 2005 Posts: 7,440 Bolter | | Bolter Joined: Apr 2005 Posts: 7,440 | This may sound redundant but did you have #1 at top dead center on the compression stroke when you dropped the distributor into place with the rotor pointing to the #1 plug wire? Might be the problem.
| | | | | Joined: Mar 2005 Posts: 1,029 Member | | Member Joined: Mar 2005 Posts: 1,029 | Or pull #1 plug, put your finger over the hole and crank the engine with the key off until you feel the compression. | | | | | Joined: Aug 2004 Posts: 1,418 ODSS Lawman | | ODSS Lawman Joined: Aug 2004 Posts: 1,418 | I agree with many above, I think you have a timing issue. you need to set your motor to top-dead-center and find the location of the number one plug on the distributer. Once you have that, then you can set you cap on from the other engine putting the wires in the proper order 153624.
I had the same issue as you did, I checked everything and the engine would turn over but nothing else would happen. I started over setting the engine to TDC on the flywheel re-did the wiring and I am back in business.....
SWEET Sergeant At Arms: Old Dominion Stovebolt Society BUNS?!?!?!Where we're going, we don't need no buns.....1950 GMC 450 1951 Chevy 1/2-TonThe GreenMachineIn the Stovebolt Gallery | | | | | Joined: Jan 2005 Posts: 364 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 364 | Originally posted by joker: does it turn over as fast as it should? Fumblin, after you've established TDC, and made sure your dist. is positined correctly, and then re-checked it, and re-re-checked it  Then make sure you can get that thing spinin' like it should, that was part of my problem when I first got mine running.
Keith If it were easy they'd have grade schoolers doing it! | | | | | Joined: Jan 2005 Posts: 1,682 Extreme Gabster | | Extreme Gabster Joined: Jan 2005 Posts: 1,682 | Had the battery on deep cycle charge overnight, going to the autoparts store for new cables.. guess i'm going to check the online manual to determine where the timing mark is, and how to tell when it's in the right position.
| | | | | Joined: Feb 2004 Posts: 29,811 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,811 | Pull the valve cover, and watch the valves on #6 cylinder. Turn the engine over (clockwise) with the fan. When the exhaust valve is about halfway closed, and the intake just starts to open, set the distributor rotor to point toward #1 plug wire. Now, turn the distributor housing clockwise until the points close, and turn it back counterclockwise until they're just barely open. Button everything up and fire it off. Works every time! Jerry
| | | | | Joined: Jan 2005 Posts: 1,682 Extreme Gabster | | Extreme Gabster Joined: Jan 2005 Posts: 1,682 | Well i've gone from "rar..rar..rar..rar.." to "rar..rar...rarrarrar...rar...rar...rarrarar"
I've got nice hot spark now on the points, and all plugs are nice and hot sparkin'.
The flywheel has a nice glaze of surface rust on it, so I can't make out any timing marks to line up with the little finger thing in the "window".
I'm going to try Hotrod Lincoln's method today.. i'm hoping it's just a matter of me not having the plug wires on right, because at present i'm not sure where the #1 spot is on the distrubuter.
