Hi; My unrestored 1954 half ton runs fine - except - if it is driven and then turned off for about ten minutes and restarted, it will go for about half a minute and then stall. It will then start with the choke (even though warm), run bad for a few minutes, and then be okay. It starts and runs fine when cold and after the stalling episode. Have new points, condenser, rotor, coil, cap, wires, plugs, and rebuilt carb. Vapor lock?? The fuel pump shows five pounds pressure. Any suggestions would be appreciated.
Rich
