| | | Forums66 Topics128,010 Posts1,055,298 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2002 Posts: 622 Member | | Member Joined: Jan 2002 Posts: 622 | "I don't care what state you live in... you cannot use a firearm & threaten deadly force with it for a property crime offense" ____________________________________
§ 9.42. DEADLY FORCE TO PROTECT PROPERTY. A person is justified in using deadly force against another to protect land or tangible, movable property: (1) if he would be justified in using force against the other under Section 9.41; and (2) when and to the degree he reasonably believes the deadly force is immediately necessary: (A) to prevent the other's imminent commission of arson, burglary, robbery, aggravated robbery, theft during the nighttime, or criminal mischief during the nighttime; or (B) to prevent the other who is fleeing immediately after committing burglary, robbery, aggravated robbery, or theft during the nighttime from escaping with the property; and (3) he reasonably believes that: (A) the land or property cannot be protected or recovered by any other means; or (B) the use of force other than deadly force to protect or recover the land or property would expose the actor or another to a substantial risk of death or serious bodily injury.
delete my account and pictures
| | | | | Joined: Sep 2005 Posts: 30 Member | | Member Joined: Sep 2005 Posts: 30 | 9.42A.
Whadda ya gonna do ? shoot a kid for smashin' your mailbox with a baseball bat ?
Ain't a jury on the face of the earth that wouldn't put you away for a long time... or...give you a seat in "Old Sparky " | | | | | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 | i finally got hold of a digital camera and wanted to post a simple, engine compartment locking device. see photos http://s67.photobucket.com/albums/h298/1951otter/ the other shots are of my under pass bed gas tank, 16 gallon w/ the old cab filler turned 180 and welded to a plate. this mounts to the passenger side, in front of the rear fender, below wood skirting. there is room for a 2'' hose to connect the filler spout to the tank inlet neck.
Jim & Caroline The highway is for gamblers, better use your good sense." Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
| | | | | Joined: Jul 2005 Posts: 227 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2005 Posts: 227 | carolines truck: would like to see the pics but its asking for me to login when i click that link? | | | | | Joined: Oct 2005 Posts: 37 Junior Member | | Junior Member Joined: Oct 2005 Posts: 37 |
1951 6400 1954 6100 dump 2 1962 IHC scouts
| | | | | Joined: Jan 2006 Posts: 55 Member | | Member Joined: Jan 2006 Posts: 55 | well I see many grate ideas one that i have found works well is a product called PZO it is a speaker that puts out a high frequncy that cosis pane and has been known to paraliss it can be atached to any car alrm. the only problem is there are about 3 state you can buy it. | | | | | Joined: Feb 2006 Posts: 564 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 564 | "Line Lock" from Hurst. It's what drag racers use to lock their front tires. Step on the brakes, hit the button, the front brakes lock. Pull the car in forward, lock the front brakes. Theif isn't looking for a hidden Line Lock switch. About $100 from Summit or Jegs, and relatively easy to install. -Brad SOUTHERN FALL GABfestOctober 6 ~ Commerce, Georgia Details here!Never Pee on an Electric Fence. | | | | | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 |
| | | | | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 | This has been posted before, but according to professional car thieves that were being interviewed by one of the TV news magazines (60 Min., 20-20, or Dateline), the most effective device was a delayed fuel shut off valve. They said a car that had no outward appearing alarms, club. chains, etc. but would die on them when they got onto a public street was one they immediately had to abandon because one just couldn't stick around with a stolen car. Might cost the owner a wrecker and pound fee but that's better than a total loss.
Evan
| | | | | Joined: Jan 2005 Posts: 8 Junior Member | | Junior Member Joined: Jan 2005 Posts: 8 | ...leave a post-it note on the steering wheel saying "dont forget to get gas!"....price of fuel should be a good deterrent...
aaahh..the smell of my old truck...
| | | | | Joined: Dec 2004 Posts: 128 Shop Shark | | Shop Shark Joined: Dec 2004 Posts: 128 | If you use an electric fuel pump - just pull the fuse.. 1 float bowl of fuel and it ain't going anywhere. I've often thought of building a 100KV capacitive discharge power supply - if someone messes with the vehicle they get 100kv up the *** from 2 probes in the drivers seat. It won't kill em but they won't stay in the truck long...  | | | | | Joined: Jul 2006 Posts: 482 Shop Shark | | Shop Shark Joined: Jul 2006 Posts: 482 | I needed a good laugh. The winners were: 1)Horn alarm INSIDE the cab. 2)Electrified car seat. 3)Electronically activated cherry bomb. Laugh out loud funny: A .22 round used as a fuse. Instant vascectomy. Probably a good thing if the guy doesn't go on to produce progeny. | | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | efi-diy,maybe add a video dash cam with it.Just imagine you forgetting to deactivate it,that picture would be priceless !! 1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
