2 members (HandyAndy, mick53), 78 guests, and 2 robots.
Topics128,050
Posts1,055,646
#19027 02/14/2005 2:33 AM
Took the cover off my rear end and found a 3:31,and with what looks like and limited slip,(springs in the carrier), with a 12 bolt cover. Does anyone know what this may of come out of?
Thanks.
'54 3100-235-T5 trans-12 bolt 3:31
'68 Impala 307/350
'78 Sportster/Original owner
#19028 02/16/2005 1:49 AM
This might be worth a try.
Look on the passenger side axle tube, on the front about half way between the diff and the hub, for a code beginning with usually 2 letters. Then search for the code # in different decoders. There are many chevelle and camero decoders on the web. Try this truck decoder first.
axle codes
