1 members (stoveboltgator), 218 guests, and 0 robots.
Topics128,048
Posts1,055,540
Members48,425
#19025 08/06/2003 3:53 AM
Pal
Offline
I have a 68 Fleetside C-10. The only gas tank in the truck currently is the cab tank. My Dad's 72 had 3 tanks, 2 saddle and one cab.
1st question: Where can you buy these saddle tanks?
2nd: Will the saddles from 73+ fit ok?
3rd: If I only put one saddle in on drivers side, would the truck feel imbalanced? (I hated turning around at the station to fill the other side)
4th: Ref. the Blazer option where the spare tire mount is: Can the filler neck be routed to the side of the bed? If so I see this as the best option. Opinions?
Oh and reason for extra gas? Fisherman, who likes undeveloped (no houses) lakes.
35 + years of rollin' steel!
The "unbalanced" feeling won't be noticable if the tank is mounted inside the frame rail next to the driveshaft; panels and 'burbs came with one tank on the passenger side and don't (shouldn't) lean. Tearing out the spare carrier seems awfully labor-intensive and will put the weight behind the rear axle, which will change the handling slightly. Ideally, the mass should be centered, but if there's any load in the bed you won't notice the difference. If it's going to see trail duty, saddle tanks are better protected from punctures due to the central location.
Regardless of where the tank is mounted, you will still need to cut a hole somewhere for the filler neck. The cleanest approach I have seen is to fab a fuel door flush to the panel and build a sheetmetal "cone" to protect the pipe where it protrudes into the bed. Another option I've seen is to use a marine fuel filler and cap, which is a round flush-mount cap and mounting ring (it looked very slick on an AD 'burb). Do you want the fill pipe to protrude into the bed fore or aft of the wheel well? Depending on what you haul and how you load it, that could be a concern.
edit: Is this what you\'re looking for?
1955 First Series GMC 250 1-Ton Panel
Mr. Hedgehog - Follow the build
If you can't laugh at yourself, I'll laugh at you.
