9 members (3B, BarryP, Ribside, DadsFirstPickup, Ol' Red, Donf, Biermann, Jon G, UtahYork),
142
Mod | | | Forums66 Topics128,134 Posts1,056,738 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2004 Posts: 90 Member | | Member Joined: Aug 2004 Posts: 90 | Has any body used Chevy Duty's 10/12 bolt 3'' rear end spring perch set up and did you have issues w/ the U bolts being to short?? I am swapping the rear end and using the stock springs and one would think that if this kit was sold to customers of AD / TF's it should fit the standard stock springs. The kit is made by classis engineering in Calif. When I called (CD), and advised them of this they said send it back, that the 'U' bolts are one length only. :confused: Well heck I've got the whole enchialada apart and I'm NOT waiting another week or two for something they don't have/ supply. CD said I had to return the entire kit to get credit and the supplier only makes the 7'' size. I'm off to a local suspension shop and have 4 made to the correct length, it took a half an hour. But it cost me $36.00 MORE. It's just a big bummer to spend that kind of money and not get what you should gotten in the first place. Their U bolt length is 7'' from the inside curve to the end of the threaded rod and I can only get one turn on the nut w/ no lock washer, and you need at least 8''. the standard nuts are .5 to .6'' long + washer and lock washer. I guess I'm just posting this as an FYI.
Any thoughts
Gooday Jim
small wheel moves by fire and rod, big wheel fires by the grace of god, everytime that wheel turns round, bound to cover just a little more ground.
| | | | | Joined: Oct 2001 Posts: 194 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2001 Posts: 194 | I got the kit from Chevy Duty too, and the u-bolts were only too short if I tried to use the original shock mounts.
I didn't use the orginal AD shock mounts and made my own. U-bolts worked just fine then. | | | | | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 | I have contacted CHEVY DUTY and they asked about my situation. REFUNDED MY COSTS for the replacement U bolts that were sent. Chevy Duty Has contacted CPP to inform them as to the WRONG length of U bolts supplied w/ the kit they make for Chevy Duty. All you have to do is ask, the squeeky wheel syndrome
CHEVY DUTY HAS COME THROUGH W/ POSITIVE FEEDBACK AND A QUALITY RESPONSE TO THIS SITUATION. I'm a satisified customer
Jim & Caroline The highway is for gamblers, better use your good sense." Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
| | | | | Joined: Mar 2005 Posts: 627 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 627 | Business as usual for them.
Mike Barnes 1950 GMC 1-ton pickup
