Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
1 members (41 chev), 120 guests, and 2 robots.
Topics128,275
Posts1,058,572
Members48,492
Anyone know what rear end gear ratio came in a 55 first series chevy 1/2 short wheel?
Jake
3.90 Jake
Larry Kephart
1937 Chevy Utility Express (Deerslayer)
1955 1st 3100 Chevy (BillyBob)
2017 Cadillac ATS-V (Elvira)
Boca Raton, Florida
e-mail: [email protected]
http://www.laroke.com/larryk4674/1998/billybob.htm
3.90 Jake
I changed to 3.08, nice on the Highway
Buddy
"Keep the shiny side up....."
'50 GMC Suburban
'55 1st Chevy Pickup
http://community.webshots.com/user/buddyinak
3.90
Bill Schickling
Bill Schickling
1940 1/2 ton, 1940 3/4 ton
My web page
3:90 Gear Ratio.
You have a couple options;
a. put in a 3:55 from Patrick's with a new bearing kit willl cost around $550 for parts.
b. put in a late 70's thru mid 80's blazer rear end, advantage here is you keep the 6 lug pattern, get bigger rear drums and the width is a perfect fit, so all you have to do is weld on new spring perches. From what I understand you can get 3:08 or 3:42 gears
c. Late 70's camaro rear end, here you can get drums, 5 lug pattern but you can also get a 3:09 or 3:42 gearing. If my memory serves me correctly some come with discs and some with drums.
When I had my 55.1 I was going to go with the blazer rear end, pretty common and I could get a good one with 3:42 gears from a boneyard for $75.00, rebuild the drums and I would have been good to go.
Hope this helps,
Chris
Chris 1955FirstSeries
