2 members (Otto Skorzeny, Hotrod Lincoln), 73 guests, and 2 robots.
Topics128,154
Posts1,056,840
Members48,456
#189857 09/21/2005 3:24 PM
Anonymous
Unregistered
Anonymous
Unregistered
I have a set of disc brakes from a 72 half ton in the swap and was asked if they would work on a 60-66 1/2 ton. The set up I have includes the spindles, rotors & calipiers. I also have the lower control arms.
Has anyone here made this modification to their truck or can point me in the direction where I can find this out?
#189858 09/21/2005 7:15 PM
It will fit,, use 71 ball joints,tie rods are diff size, you can get a tie rod sleeve adapter from Classic Performance Products or use later model drag link assy. Brian
My \'64\'s in the Gallery
Pictures in my Photobucket
1964 C10 Custom Cab 350/700R4
1964 Suburban 350/700R4
1979 Ford F350 4x4 400/c6
#189859 09/21/2005 7:21 PM
Do disc breaks preform better than drum brakes???
#189860 09/21/2005 7:24 PM
I have one 64 with discs & one without, the difference is amazing. Brian
#189861 09/21/2005 7:42 PM
Anonymous
Unregistered
Anonymous
Unregistered
It is DISC BRAKES!
64 - Clarification please. The 60-66 control arms will work with the new ball joints or would the control arms also have to be swapped?
#189862 09/21/2005 11:00 PM
Interesting..... I have stock drum on my '66 and I must say, they havent been easy to get used to.
#189863 09/22/2005 2:15 AM
Are 60-62 control arms the same as 63-66?
Since the earlier trucks use torsion bars and the later ones are coil springs I would expect the control arms to be different.
Are the ball joints the same? Is so it seems likely the swap would be possible.
#189864 09/22/2005 3:34 AM
The 71-72 disc ball joints fit in the stock control arms on my 64, the ball joints/arms are entirely diff on 60-62 torsion bar trucks. Brian
#189865 09/22/2005 3:51 AM
I wondered. Houston I think the answer is that they will work for '63 - '71 disk brake conversions, but not for the earlier trucks.
#189866 09/22/2005 4:09 AM
Anonymous
Unregistered
Anonymous
Unregistered
Thanks. The person interested in my spindles evidently has a 64. I will pass the information along. Of course he will also need a proportioning valve and dual MC.
#189867 09/22/2005 11:32 PM
Still staying in Houston Houston?
#189868 09/23/2005 12:15 AM
Anonymous
Unregistered
Anonymous
Unregistered
Steve,
Thanks for the concern. If we had some other place to go we would not be able to get there. The entire metro area is in gridlock going north, east or west. No stations have any fuel. People are running out of gas in traffic. There are no hotel rooms within 600 miles.
We are well prepared. Have fuel, food, family and friends. Have generator, water, scotch, cigars, and a truck in the garage to wrench on if I need to blow off steam.
Have boarded up windows to put the wife at ease, have set up neighbors with supplies, have gassed up the chain saws for the aftermath, and have invited the insurance agent (also friend) over for dinner tonight.
We are expecting wind damage and will be pleasantly surprised if it does not occur.
We really need some rain as the lake is down about 20 inches from normal and my shrubs are getting very thirsty. We would appreciate all the prayers and kind thought you and other can send our way.
There are so many people on the road still at this time and I certainly hope they have a destination and a full tank. Keep them in your thoughts also.
If there are any Houston area Stovebolters that need a garage for the duratio, get in touch with me now. We will make room.
#189869 09/23/2005 2:14 PM
Junior Member
Junior Member
Well i wish you the best of luck.
#189870 09/23/2005 3:19 PM
Keep us posted as you can!
