| | | Forums66 Topics128,030 Posts1,055,418 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2005 Posts: 27 Junior Member | | Junior Member Joined: May 2005 Posts: 27 | I'm looking to get another frame for my 62 stepside that I can build while still driving my truck. Then when the frame is finished the down time will be drastically reduced. I'll just put my body on a different chassis. In doing so, I'd like to add a few things like power steering and disk brakes. I'm looking for a 64 to 66 frame with front coil springs. Would a 70's frame bolt up the same way since the rear suspension looks the same? What year frame do you all suggest? Thanks.
Priorities make dreams happen.
| | | | | Joined: Apr 2004 Posts: 158 Shop Shark | | Shop Shark Joined: Apr 2004 Posts: 158 | If you switch to anything newer than '62 you'll be making a switch to spring front end instead of torsion bars.
I understand that the 67-71 frames are VERY similar to the 64-66. I know that the rear axle is a bit wider, but I think that might be your best bet. 71, of course, is the first year for front disk brakes.
Brian | | | | | | Anonymous Unregistered | | Anonymous Unregistered | hehe, funny, I was going to ask this same question yesterday. If a 71-72 frame with discs is an easy swap for a 60-66 body? | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | hehe funny.
No frame swap is going to be easy!
I've not done it, but I expect this swap would be a lot easier than some of the other frame swaps people try. The differences between frame and suspension may not be much. The changes are more likely to be exactly where and how the body mounts, and where some holes and brakets are located.
I don't know details on 60-72 trucks, but looking at 47-54 trucks you have several small changes year to year affecting different aspects of a swap like this. I would expect you'll see some of the same issues, only more so, in a swap like this.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: May 2005 Posts: 27 Junior Member | | Junior Member Joined: May 2005 Posts: 27 | I guess I should just whip out the old tape measure and go to town.
| | | | | Joined: Jan 2001 Posts: 613 Member | | Member Joined: Jan 2001 Posts: 613 | the bumper mounts on front are different on the 67-72. | | |
