| | | Forums66 Topics128,180 Posts1,057,145 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2001 Posts: 258 'Bolter | | 'Bolter Joined: Aug 2001 Posts: 258 | This is for anybody with '54 & '55 first-series trucks with factory-equipped turn signals...
I am having trouble getting my turn signals to work on my '55 first series dump truck...
The Flare-Stat four-ways work, so I know the bulbs and wiring to the lights are good...
I've swapped the two flashers between the 4-ways and the turns, and both flashers are good...
Should I be planning to pull the steering-wheel and dig into the turn signal switch ?
This is my first AD with factory signals...
Frank McMullen 1941 Chevy dump truck 1949 GMC 100 pick-up 1954 Chevy 3600 pick-up 1955.1 4400 dump truck 1941 De Soto & other MoPars 1928 Model A F**D Special Coupe
| | | | | Joined: Apr 2002 Posts: 1,571 Shop Shark | | Shop Shark Joined: Apr 2002 Posts: 1,571 | Are they not working at all? Could be a broken wire or a dirty contact. The switch is easy to remove, just mark the position of the steering wheel so you can put it back in the right spot on the splines. I'd check the wiring running to the column before digging into the wiring there. | | | | | Joined: Apr 2005 Posts: 7,441 Bolter | | Bolter Joined: Apr 2005 Posts: 7,441 | Had a loose plug in the wiring of the switch on mine. Just pushed it in firmly and it now works fine.
