3 members (jasrking, LAROKE, 3800GUY), 75 guests, and 5 robots.
Topics128,181
Posts1,057,152
Members48,464
This is for anybody with '54 & '55 first-series trucks with factory-equipped turn signals...
I am having trouble getting my turn signals to work on my '55 first series dump truck...
The Flare-Stat four-ways work, so I know the bulbs and wiring to the lights are good...
I've swapped the two flashers between the 4-ways and the turns, and both flashers are good...
Should I be planning to pull the steering-wheel and dig into the turn signal switch ?
This is my first AD with factory signals...
Frank McMullen
1941 Chevy dump truck
1949 GMC 100 pick-up
1954 Chevy 3600 pick-up
1955.1 4400 dump truck
1941 De Soto & other MoPars
1928 Model A F**D Special Coupe
Are they not working at all? Could be a broken wire or a dirty contact. The switch is easy to remove, just mark the position of the steering wheel so you can put it back in the right spot on the splines. I'd check the wiring running to the column before digging into the wiring there.
1954 GMC De Luxe COE
Had a loose plug in the wiring of the switch on mine. Just pushed it in firmly and it now works fine.
