3 members (baldeagle, BarryP, Jay R), 387 guests, and 5 robots.
Topics128,163
Posts1,057,070
Members48,463
Need a bit of help on a Spitfire 1500. New coil, points, condenser, cap and plugs. Get very weak spark at points - nothing out of the cap. Everything set to specs. Seems to be a short somewhere. My 6 volt truck system kicks out a blue spark - the Triumph shows a weak spark. Battery shows 12+ volts. How do I track a short? Am I overlooking the obvious? Has a Delco distributor, BTW. BW
Sometimes parts are bad out of the box. Try swapping in the old ones one at a time (only ne "old" part at a time). You might find a bad condenser or coil. Also, is the engine grounded well? Check the engine ground strap for good contact. A bad ground will interfere with the ignition, as would a short between the dist. power supply and ground.
Are you cranking this with the starter? If it has a weak spark while cranking but a good spark by manually flipping the points then your battery cables and engine grounds are corroded or too small, causing resistance. The starter is taking all the juice.
Paint & Body Shop moderator
Weak spark by manually flipping the points. 12 volts at battery, 12 volts at solenoid with switch on, 6 volts at coil - switch on. Negative lead grounded on the trans. I am guessing that something is wrong with the ignition switch / resistor? I can not get spark out of the distributor at all. Hmmm! BW
R.Wyant,
I think you want a "weak" spark "at the points"...this is the primary side of the ignition, not the "blue spark" secondary side. If this is a 12 volt system with no resistor wire or ceramic start/run resistor to the primary (key) side of the coil, I would expect 12 volts with key turned on. I might not understand what you are asking!
Stuart.
R.Wyant,
Can't sleep..must expound on stuff I know nothing about! If it is a 12 volt system there should be 12 volts at the + (key) side of the coil with the key turned on. I don't know if it RUNS at this voltage or not, but it could. Turn the key on, pop the cap, and with a screwdriver, open the points and you should be able to get the coil wire to ZAP to a ground. Don't go through the cap, just fire the coil to ground. If this works, you have a cap/rotor issue. The condensor quenches the arc as the points open, there should not be a huge flash from opening
the points with the key on. There, I'm done!
Stuart.
On a 12 volt ignition with ballast resistor you should see 12 volts on the coil + with the points open and about 6 volts with the points closed unless the starter is cranking. With the starter cranking, you will see the same voltage at the coil + as at the starter with points open or closed (will be less than 12 v due to starter drag). The coil - will be 12 v points open and 0 v points closed.
