| | | Forums66 Topics128,157 Posts1,056,880 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2005 Posts: 42 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2005 Posts: 42 | I've been discussing the issue with a friend over the net & I'm not sure what the right answer is. | | | | | Joined: Apr 2003 Posts: 608 Shop Shark | | Shop Shark Joined: Apr 2003 Posts: 608 | to my knowledge,the last production year was 1953 thriftmaster 216 engines and 235 jobmaster engines.Starting in 1954,the 235,s became the thriftmaster and did not have a splash system, it was all pump lubed, but with the option of a bypass oil filter. The 261 engines also offered an optional filter but if not installed the oil ports on the block had to be looped (or piped) together not just plugged like a 235 or you would starve the engine of oil and SPIN A BEARING OR TWO  p. s. the earlier engines had the filter option also. | | | | | Joined: Aug 2000 Posts: 587 Shop Shark | | Shop Shark Joined: Aug 2000 Posts: 587 | 1954, when the new 235 engine came out. New as opposed to the 235 in use prior to 1954 on larger trucks, which also used a splach oiling system. | | | | | Joined: Jul 2003 Posts: 132 'Bolter | | 'Bolter Joined: Jul 2003 Posts: 132 | The 1953 model year cars had splash oil with standard transmissions, and the 235 pressure lube with Powerglide. I put one of those is my second car, a 1952 Deluxe standard. (boy, I wish I had that one back).
I think all trucks still had splash in '53.
Everything went to pressure lube in '54.
But, 53 and 54 pressure lube still had shimmed mains I think. | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | I think KENC is correct in all his statements. | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | You guys aren't giving enough credit to "Chevrolet's exclusive four way lubrication system". I really enjoy reading the old pamphlets! | | | | | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | Early 54 was the end of shimmed mains. Shims went away when the larger journal cam was intoduced.
Fred 52 3600 69 C-10
