7 members (MickeyP, RoadsScholar, Gdads51, 1955 1 Series, thekid1950, tclederman, klhansen),
117
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,081 Posts1,056,068 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#18944 09/11/2003 12:42 PM | Joined: Aug 2000 Posts: 800 Shop Shark | | Shop Shark Joined: Aug 2000 Posts: 800 | We were checking out how to do a MC swap in the '45 and it doesn't llok as though the AD version is going to work in the Art Deco. We're going to modify the stock bracket and that looks good. The problem is the Mustang MC that was recommended has it's lines coming out the wrong side.(passenger side) I need one that can have the lines on the opposite side. This will remain drum/drum. | | |
#18945 09/11/2003 12:53 PM | Joined: Jul 2000 Posts: 504 Member | | Member Joined: Jul 2000 Posts: 504 | Pete, with the proper bending tools, brake lines can be easily bent to accomodate that master cylinder.. Where are you going to run the brake lines , on which frame rail ?
Bill M 53 GMC Hydra-Matic
Home Page http://home.comcast.net/~bd97/index.html
When you argue with a fool, two fools are arguing..
#18946 09/11/2003 1:46 PM | Joined: Feb 2001 Posts: 96 Shop Shark | | Shop Shark Joined: Feb 2001 Posts: 96 | | | |
#18947 09/11/2003 1:47 PM | Joined: Aug 2000 Posts: 800 Shop Shark | | Shop Shark Joined: Aug 2000 Posts: 800 | Bill, they're going to be very tight to the tranny if they come out to pass. side. It looks as though the drivers side is the best for the lines, though there's a crossmember not far back from the master as well. | | |
#18948 09/11/2003 4:05 PM | Joined: Mar 2000 Posts: 784 'Bolter | | 'Bolter Joined: Mar 2000 Posts: 784 | k10 - I don't know what trans you are using but on my 46 with the stock 3 spd there was plenty of room on the passengers side of the master. The lines turn down 90 right out of the master then forward toward the cross member, along the cross member to the passenger side frame rail, then one goes foward and the other back. It might a little tighter with a 4 spd but I think it should work. Send me a PM if you want some pictures of my setup. I don't have the tecnology to post them here. I have the body off right now so every thing is right out there in the open. Good Luck George | | |
#18949 09/11/2003 5:58 PM | Joined: Feb 2000 Posts: 769 Shop Shark | | Shop Shark Joined: Feb 2000 Posts: 769 | Check out this web site for brake parts and dimensions and discriptions for master cylinders. www.mpbrakes.com | | |
