9 members (55shaker, 1955 1 Series, BC59, 3800GUY, RaNfLaS, tclederman, Otto Skorzeny, wilbur53, FAST55), 156 guests, and 0 robots.
Topics128,104
Posts1,056,201
Members48,436
#18905 04/21/2002 9:37 PM
Anybody out there ever used one? I'm curious to know how well one would hold up in an Advance Design pickup, behind a mild 305 V-8. Truck wouldn't be used as a truck very often, and would never haul huge loads.
Thanks in "Advance"
Wannabe smile
"Don't expect anything and you'll never be disappointed"
#18906 04/22/2002 4:07 AM
That tranny should hold up fine behind a 305. They have better gear separation than 700R4's, and can be built to take a lot of abuse if you ever decide to put something hot in front of it. Ask a Grand National or turbo T-Type owner/racer. You'll have to get an adapter however, as they are a B.O.P. bolt pattern. I think the overdrive is definately worth it though. Have fun.
Rollin' Hard
1946 Chevy 1/2 ton
1959 Phord 1/2 ton
2001 Chevy 1/2 ton
#18907 04/22/2002 7:24 PM
Actually, Jeff C they have a dual bolt pattern, both B.O.P. and Chevy. They were standard equipment in some mid eighties Caprices with the 305. That's why I was asking-seems like a good way to finish off my drivetrain all in one shot with the same (hopefully cheap) parts car. I'd forgotten about the gear ratios and the usage in GN's, though. Thanks for your input, my fellow Canuck.
Wannabe smile
#18908 04/24/2002 7:52 AM
I put one in my '66 panel behind a stock 350. I have a 3.07 rear so pull about 1900 rpm at 70 in OD. I still have enough grunt off the line to satisfy me. I really like it
57 3/4 ton rat
66 C-10 panel 350 200R4 3.07 axle
68 C-20 dump runner, 250 4spd, 4.11
82 Camaro, 305, THM-200-R4
84 Monte Carlo, 350, TH350
EVERETT, WA
