| | | Forums66 Topics128,077 Posts1,056,013 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#18905 04/21/2002 9:37 PM | Joined: Jan 2002 Posts: 398 Member | | Member Joined: Jan 2002 Posts: 398 | Anybody out there ever used one? I'm curious to know how well one would hold up in an Advance Design pickup, behind a mild 305 V-8. Truck wouldn't be used as a truck very often, and would never haul huge loads. Thanks in "Advance" Wannabe
"Don't expect anything and you'll never be disappointed"
#18906 04/22/2002 4:07 AM | Joined: Aug 2001 Posts: 78 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2001 Posts: 78 | That tranny should hold up fine behind a 305. They have better gear separation than 700R4's, and can be built to take a lot of abuse if you ever decide to put something hot in front of it. Ask a Grand National or turbo T-Type owner/racer. You'll have to get an adapter however, as they are a B.O.P. bolt pattern. I think the overdrive is definately worth it though. Have fun.
----------------------------------- Rollin' Hard 1946 Chevy 1/2 ton 1959 Phord 1/2 ton 2001 Chevy 1/2 ton
#18907 04/22/2002 7:24 PM | Joined: Jan 2002 Posts: 398 Member | | Member Joined: Jan 2002 Posts: 398 | Actually, Jeff C they have a dual bolt pattern, both B.O.P. and Chevy. They were standard equipment in some mid eighties Caprices with the 305. That's why I was asking-seems like a good way to finish off my drivetrain all in one shot with the same (hopefully cheap) parts car. I'd forgotten about the gear ratios and the usage in GN's, though. Thanks for your input, my fellow Canuck. Wannabe
#18908 04/24/2002 7:52 AM | Joined: Jul 2000 Posts: 23 Member | | Member Joined: Jul 2000 Posts: 23 | I put one in my '66 panel behind a stock 350. I have a 3.07 rear so pull about 1900 rpm at 70 in OD. I still have enough grunt off the line to satisfy me. I really like it
57 3/4 ton rat 66 C-10 panel 350 200R4 3.07 axle 68 C-20 dump runner, 250 4spd, 4.11 82 Camaro, 305, THM-200-R4 84 Monte Carlo, 350, TH350 EVERETT, WA
