| | | Forums66 Topics128,023 Posts1,055,370 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2005 Posts: 157 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2005 Posts: 157 | Probably no useful information in this post, other than I see why you guys all say that Rochester carbs are a POS.
My carb was pretty much full of sludge and leaking - an obvious candidate for a rebuild. After having the tank boiled out and coated, and flushing out all the fuel lines and the filter, I ordered a NAPA carb rebuild kit and overhauled it. The carb had about 1/8" crud in the bottom of the bowl. The big problem with these carbs is that there is no good way of cleaning out the accelerator pump passages underneath the plunger. I had to carefully drill out the lead plug on the outside of the bowl assembly to open up the supply passage. Resealed it with JB-quick.
The engine started and ran beautifully. Took it for a 5 mile drive and it ran great. However, when I backed it into the barn, all of a sudden it went dead rich and barely ran. That's where it's at right now, something's stuck. It isn't the float, so it looks like disassembly is in order.
Are Carter carbs a direct bolt on, including air filter? Would I be smart to just pitch the Rochester and switch?
Thanks for your advice as usual. | | | | | Joined: Mar 2005 Posts: 627 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 627 | How do you know it isn't the float? Depending on who mage your kit, Rochesters gaskets are known to hang up the float if not trimmed carefully. If it isn't leaking you have a very good well above average Rochester that is probably worth fixing. They work great when set up right, again with the common issue being leaks due to warped castings. Carter bolts right on and your old filter will fit like a glove.
Mike Barnes 1950 GMC 1-ton pickup
| | | | | Joined: Jan 2005 Posts: 310 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 310 | The Carter YF is a direct bolt on replacement. Just be certain you get one for a Chevy 6, because they made YF's for Jeep 4's, Studebakers, etc. Try it. You'll wonder why you didn't switch sooner.
-Tim '51 Chevy 3104 w/'56 235, 848 Head, HEI Dizzy, Corvette Cam, Split Manifold and Dual Carter YF's
| | | | | Joined: Aug 2001 Posts: 258 'Bolter | | 'Bolter Joined: Aug 2001 Posts: 258 | Umm...
A lot of carb guys don't have much good to say about the Rochester B, due to the warpage issue... the later castings have stiffener ribs in the top cover, and warp less than the early models. The later B's have larger fillister-head screws securing the cover to the bowl, and thicker bosses where the screws go through the bowl cover.
GM used the B from '49 through '67, it must have been "adequate".
I have had Carter YFs on stovebolts and Willys as well, and some have been fine and others have been nightmares.
Before you throw your B, make sure that the float is set correctly and that the arms/floats aren't dragging on the bowl or the gaskets, and try again.
If it doesn't leak, the B is still my preferred carb for stovebolt drivers...
In fact, I've been running a Rochester BV ("divorced choke") on my '72 C-10 for over 25,000 miles, replacing the OEM Rochester Mono-jet and its "Transmission-Controlled Spark" goofy early emissions carb.
Good luck !
Frank 54
Frank McMullen 1941 Chevy dump truck 1949 GMC 100 pick-up 1954 Chevy 3600 pick-up 1955.1 4400 dump truck 1941 De Soto & other MoPars 1928 Model A F**D Special Coupe
| | | | | Joined: Aug 2005 Posts: 157 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2005 Posts: 157 | Well, it was no big deal fixing the carb. I took a closer look this morning, and saw something laying in the float bowl. Oops, it was the main jet. I must have not tightened it down tight enough. Replaced it, and the truck runs fine.
My wife gave me a rough time about it until I reminded her of the time she put her bra on upside down. ;>) | | | | | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | did she purr better after that,,,,just kidding,,glad you got it fixed,,,,,Fred Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | | | | Joined: Apr 2005 Posts: 313 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 313 | I had the same thing happen to me several years ago. | | | | | Joined: Aug 2005 Posts: 157 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2005 Posts: 157 | Originally posted by Doug 57: I had the same thing happen to me several years ago. The jet or the bra? | | |
