| | | Forums66 Topics128,038 Posts1,055,583 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2004 Posts: 328 Member | | Member Joined: Nov 2004 Posts: 328 | After a long time that I couldn't figure out what was wrong, I believe I've found it. A guy told me my valves were tapping and they needed adjusting. It's a V-8, and it's been acting very sluggish in 1st, sometimes low-rpm 2nd gear.
I think he's right, but how do I adjust these? Is this an easy job?
Thanks guys, I feel like I haven't been here in months...good to be back. | | | | | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | Which V8 is this? Most of them have hydraulic lifters, and if they are tapping and you are getting poor performance that means the camshaft is probably shot.
It is a pretty easy job to adjust them, but you need to find out if they are hydraulic or solid because the procedure is just about opposite between them.
Paint & Body Shop moderator A lone amateur built the Ark. A large group of professionals built the Titanic. | | | | | Joined: Nov 2004 Posts: 328 Member | | Member Joined: Nov 2004 Posts: 328 | alright, i'll check and be back with more information about the hydraulic or solid lifters... | | | | | Joined: Nov 2004 Posts: 328 Member | | Member Joined: Nov 2004 Posts: 328 | 85 305 V8, I think they're hydraulic. | | | | | Joined: Jul 2005 Posts: 226 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2005 Posts: 226 | Could be a collapsed hyd lifter but i doubt it... could be a busted rocker too, Probably flat cam... older small block cheyvs are notorious for flat cams... thats one reason for a roller cam...  and after rereading ur post, yeah im sure its a flat cam... uhhhhhhh careful wrappin that engine out... youll start bendin pushrods next.. pull the valve cover,,and watch the rockers..bet one or two wont hardly move,,,,or do a compression check,,it will probably show up there too....
What it will say on my Tombstone: "Boy, that guy sure owed alotta people Money"
| | | | | Joined: Nov 2004 Posts: 328 Member | | Member Joined: Nov 2004 Posts: 328 | so installing a roller cam wouldn't be a problem? So, if a couple of you have agreed it sounds like a cam problem, do I need to worry about the valve thing? I don't really know if it is the valves, but that guy said that's what it sounded like when I talked about it.
FYI: Here's some symptoms: Sluggish in 1st gear, feels like as I'm revving up it's running out of gas, even though I've got a full tank. 2nd gear it doesn't do it that often, but occasionally. 3rd gear, never does it. I didn't hear anything "tapping" but I could be deaf
So you say a compression test would yeild results huh? I may go get one of those and check it out. | | | | | Joined: Oct 2003 Posts: 445 Shop Shark | | Shop Shark Joined: Oct 2003 Posts: 445 | do as fatweed said.check the action of the rocker arms.have to remove the valve cover to check.Check rocker arms and for bent push rods.When ya find the noisie one.Use a piece of hose.One end to you ear the other end to the tappet.You'll hear the loose one.The valve clearance is 0. on intake$exhuast valve.Tighten down till engine starts to miss,then back off 1/2 turn.your set.If this makes no differnce.Could be a bad lifter OR cam lob is worm.Usually its the cam. .So new cam and lifters are in order.Summit has cam &lifters priced right.A roller is going to cost ya some bucks
dan-pa
