5 members (jmoore, fonz8261, gswbbc, Lugnutz, Dennys28), 78 guests, and 3 robots.
Topics128,031
Posts1,055,434
Members48,422
#188710 08/29/2005 7:52 PM
After a long time that I couldn't figure out what was wrong, I believe I've found it. A guy told me my valves were tapping and they needed adjusting. It's a V-8, and it's been acting very sluggish in 1st, sometimes low-rpm 2nd gear.
I think he's right, but how do I adjust these? Is this an easy job?
Thanks guys, I feel like I haven't been here in months...good to be back.
GO RANGERS grin
Photos Updated so check them out!
#188711 08/29/2005 9:43 PM
Which V8 is this? Most of them have hydraulic lifters, and if they are tapping and you are getting poor performance that means the camshaft is probably shot.
It is a pretty easy job to adjust them, but you need to find out if they are hydraulic or solid because the procedure is just about opposite between them.
Paint & Body Shop moderator
#188712 08/29/2005 11:34 PM
alright, i'll check and be back with more information about the hydraulic or solid lifters...
GO RANGERS grin
#188713 08/29/2005 11:49 PM
85 305 V8, I think they're hydraulic.
GO RANGERS grin
#188714 08/30/2005 12:03 AM
Could be a collapsed hyd lifter but i doubt it... could be a busted rocker too, Probably flat cam... older small block cheyvs are notorious for flat cams... thats one reason for a roller cam... smile and after rereading ur post, yeah im sure its a flat cam... uhhhhhhh careful wrappin that engine out... youll start bendin pushrods next.. pull the valve cover,,and watch the rockers..bet one or two wont hardly move,,,,or do a compression check,,it will probably show up there too....
What it will say on my Tombstone: "Boy, that guy sure owed alotta people Money"
#188715 08/30/2005 12:37 AM
so installing a roller cam wouldn't be a problem?
So, if a couple of you have agreed it sounds like a cam problem, do I need to worry about the valve thing? I don't really know if it is the valves, but that guy said that's what it sounded like when I talked about it.
FYI: Here's some symptoms:
Sluggish in 1st gear, feels like as I'm revving up it's running out of gas, even though I've got a full tank. 2nd gear it doesn't do it that often, but occasionally. 3rd gear, never does it. I didn't hear anything "tapping" but I could be deaf
So you say a compression test would yeild results huh? I may go get one of those and check it out.
GO RANGERS grin
#188716 08/30/2005 5:08 AM
do as fatweed said.check the action of the rocker arms.have to remove the valve cover to check.Check rocker arms and for bent push rods.When ya find the noisie one.Use a piece of hose.One end to you ear the other end to the tappet.You'll hear the loose one.The valve clearance is 0. on intake$exhuast valve.Tighten down till engine starts to miss,then back off 1/2 turn.your set.If this makes no differnce.Could be a bad lifter OR cam lob is worm.Usually its the cam. .So new cam and lifters are in order.Summit has cam &lifters priced right.A roller is going to cost ya some bucks
dan-pa
