3 members (WICruiser, Charles in CA, Otto Skorzeny), 37 guests, and 2 robots.
Topics128,029
Posts1,055,417
Members48,422
#188627 08/27/2005 11:59 PM
I am not sure this is the proper forum for this, but here goes! I was cutting up a 55/1st cab with my sawzall in preparation for a trip to the dump. As I sawed from the rear window opening around to the drivers side the sawzall caught on something and jumped and squealed, refusing to go much. I pushed a little harder, then tried it from the other direction, which worked. After removing the top, what did I find in the cubby hole between the inner and outer panels? I found a 30 round M-14 clip with 15 bullets in it...I had sawed the bottom off and the spring fell out.
Laying along side this was a plastic holder with three 30-30 shells in it. Evidently they had been shoved into the roof area and had fallen down..there was no headliner in this truck. My son thought it was a cool find. I am not gun wise and thought maybe I could have fired them had I hit them just right with the sawzall. The real scary part is that I almost used a torch! Maybe this is what you get when you chop up a AD truck!! Maybe God is a Stovebolter.
Stuart.
#188628 08/28/2005 6:27 AM
Ya just never know what your going to find in an old vehicle. Really good thing you didn't use that torch for sure!
BTW...If I'm not mistaken, I think the M-14 took a 20-round magazine not a 30-round. It might be for something else?
Mike
1958 Chevy 3200 Fleetside
1958 GMC 100 Wideside
Did you get free advice today? To donate to this site using PayPal is fast and EZ. Click here: http://www.stovebolt.com/office/thanks.html
#188629 08/28/2005 12:24 PM
62401
Wow. Too bad about sawing through it, those. Those magazines are worth a couple of bucks.
What did you do with the rounds? Did they have painted tips? If so, what color???
Sounds like someone was coming back from the range with saved rounds...
~ John
1949 Chevrolet 3804
1973 IH 1310 Dump
1963 Kaiser M38A1
2014 Ford E-350 4x4 (Quigley)
#188630 08/28/2005 5:23 PM
If you get a round of ammunition hot enough to ignite the powder, there will be a flash and a bang, but the bullet will only go a couple of feet.
Without the chamber and barrel directing and controlling the pressure of the explosion, it won't be as interesting as a firecracker.
Brian
#188631 08/28/2005 5:31 PM
The brass will go further than a couple of feet.
#188632 08/29/2005 3:39 AM
John,
The bullets say .223 win super and they have a copper jacket except for about a 1/16" on the end that is lead. Found next to these items was the remains of a firewood cutting permit.
Methinks they were getting wood but keeping an
eye out for Big Buck at the same time...probably out of season.
Stuart.
#188633 08/29/2005 4:52 AM
M-14s use 7.62 mm ammo. It might be from an M-16, an AR-15 or a hunting rifle chambered for that round.
