9 members (cmayna, Nick in Manitou, Hanks custodian, RdsLessTaken, homer52, Gdads51, mick53, kurbside bolter, 1 invisible),
79
Mod | | | Forums66 Topics128,264 Posts1,058,355 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2005 Posts: 144 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2005 Posts: 144 | I'm converting my 46 Chev 1/2 ton over to a set of modern shocks as the old lever style shocks are shot. I welded a set of universal lower mount brackets onto the rear axle and am going to weld a crossmember on top for the top mounts. Does anyone know how do I determine the proper shock to mount. Do I measure the length. A chassis rebuild book says they have to be mounted a minimum of 30 degrees of angle and 20% of further travel beyond the frame sitting level on the leafsprings. Any info would be appreciated. bobt | | |
