0 members (),
196
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,081 Posts1,056,078 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2004 Posts: 288 Shop Shark | | Shop Shark Joined: Jan 2004 Posts: 288 | Okay gang here is my report so far on the progress I made putting in new vent glass on my 55.1.
First I cut the cork/fabric setting tape I got from Chevy Duty and placed in the channel. I did cut the setting tape in a few places in the bends to allow for no crimping.
Once the setting tape was in place I used a flat head screwdriver to solidly push the tape in place.
Next came the glass and a rubber mallet. I began to slide the glass in and when it got tight I used the mallet, gently, to ease the glass in. Keep an eye on the setting tape to keep it even on both sides of the glass. Periodically I had to stop and pull the setting tape out of the channel and back around even on both sides of the glass.
As the glass got in deep enough I closed the vent and lined up the glass with the vent frame, making sure the glass wasn't in to deep.
Both windows took me about 45 minutes to install, I should note I put the setting tape in dry. I will be soaking with mineral spirits this evening and letting it set up overnight.
All in all a very pleasant experience and I hope it is that easy for you all!
Thanks to all the bolters who chimed in and offered me advice on the subject before I tackled my project.
-Chris (GBTS..God Bless The Stovebolts)
Chris 1955FirstSeries
| | | | | Joined: Feb 2005 Posts: 399 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2005 Posts: 399 | You did mineral oil didn't you? | | | | | Joined: Jan 2004 Posts: 288 Shop Shark | | Shop Shark Joined: Jan 2004 Posts: 288 | I will be soaking the setting tape now that the vent glass is in place. The shop manual says to install dry and then soak after the glass is set.
I am going to go the mineral oil route.
-Chris
| | | | | Joined: Feb 2005 Posts: 531 Shop Shark | | Shop Shark Joined: Feb 2005 Posts: 531 | Thanks for the report Chris! Question: Did you remove the entire vent window assembly or intall it while the frame was in place? | | | | | Joined: Jan 2004 Posts: 288 Shop Shark | | Shop Shark Joined: Jan 2004 Posts: 288 | Hey Larry,
I left the entire assembly in place since all I wanted to do was replace the glass. I did support the bends with my hand when I had to tap in the glass with the rubber mallet though.
Worked very slick.
-Chris
