8 members (JW51, Woodcmiami, Gdads51, dt235sd, MickeyP, HandyAndy, k2handyman, 1 invisible), 58 guests, and 1 robot.
Topics128,049
Posts1,055,699
Okay gang here is my report so far on the progress I made putting in new vent glass on my 55.1.
First I cut the cork/fabric setting tape I got from Chevy Duty and placed in the channel. I did cut the setting tape in a few places in the bends to allow for no crimping.
Once the setting tape was in place I used a flat head screwdriver to solidly push the tape in place.
Next came the glass and a rubber mallet. I began to slide the glass in and when it got tight I used the mallet, gently, to ease the glass in. Keep an eye on the setting tape to keep it even on both sides of the glass. Periodically I had to stop and pull the setting tape out of the channel and back around even on both sides of the glass.
As the glass got in deep enough I closed the vent and lined up the glass with the vent frame, making sure the glass wasn't in to deep.
Both windows took me about 45 minutes to install, I should note I put the setting tape in dry. I will be soaking with mineral spirits this evening and letting it set up overnight.
All in all a very pleasant experience and I hope it is that easy for you all!
Thanks to all the bolters who chimed in and offered me advice on the subject before I tackled my project.
-Chris (GBTS..God Bless The Stovebolts)
Chris 1955FirstSeries
You did mineral oil didn't you?
I will be soaking the setting tape now that the vent glass is in place. The shop manual says to install dry and then soak after the glass is set.
I am going to go the mineral oil route.
-Chris
Thanks for the report Chris! Question: Did you remove the entire vent window assembly or intall it while the frame was in place?
Larry Bear
55.5 Chevy 3100 Panel
Hey Larry,
I left the entire assembly in place since all I wanted to do was replace the glass. I did support the bends with my hand when I had to tap in the glass with the rubber mallet though.
Worked very slick.
-Chris
