| | | Forums66 Topics128,049 Posts1,055,679 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#18822 03/22/2002 7:43 AM | Joined: Feb 2001 Posts: 198 Shop Shark | | Shop Shark Joined: Feb 2001 Posts: 198 | I rebuilt my Monojet last week and bent the arm from the power pump to the metering rod to spec.....atleast I think I did, cause now the truck coughs and sputters when you step on the throttle. It runs lean. Have to use the choke to get it to anything close to properly. I pushed the arm down as far as it would go and then did the measurement. However I didn't have the actual metering rod attached, sssoooo I'm thinking this would have given me a false starting point. I plan on re-measuring, but I want to make sure you're supposed to have the metering rod attached. All the paper work with the kit says is to push the arm and pump down near a flat surface and measure. Thanks.
Attitude - The difference between an adventure and an ordeal! Deja Moo - The feeling you've heard this bull**** before! '63 Chev Fleetside Longbox 'Rusto-rod' 'Big Red' '69 or'70 or ? Mantaray DuneBuggy
