| | | Forums66 Topics128,021 Posts1,055,349 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2005 Posts: 6 Junior Member | | Junior Member Joined: Aug 2005 Posts: 6 | can anyone tell me the size of my engine, its a 1935 chevy...and the closest headgasket people in my area have is a 1937 216 s-6. Thanks if anyone can help me | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | I think the 207 was used up through '36, but the first thing to do is confirm what motor you have. Its not unusual for a 70 year old vehicle to have been updated a time or two. Check the casting numbers against the info at inliners.org to be sure what you have.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Aug 2005 Posts: 424 Shop Shark | | Shop Shark Joined: Aug 2005 Posts: 424 | My '34 had a 206 in it. Follow OldSubs advice and check the casting numbers though for sure. Also make sure that you have a '35 head and not some other year. I know from experience!! I bought a gasket set for my '34. No problem! Everything seemed to be the right. I had new babbit type bearings poured (yikes! that was big bucks) and I assembled the engine. I held the head gasket up to the block, no problem, all the bolt holes lined up and everything! I was home free! However, one thing I didn't know at the time (or even notice) was that Chevy had changed the head just slightly from '34 to '35 and the coolant holes on the head were slightly different. I torqued the head down and when I went to fill the radiator with coolant the first time, I was amazed at how much water and coolant the system took!! Suddenly there was coolant/water running out the exhaust pipe!
It turns out I had a '35 head on a '34 block and what I had done was fill up not only the radiator, but the crankcase and the cylinders of my brand new engine with coolant. I was fit to be tied!! :mad:
I guess what I'm saying is make sure you know what block AND what head you have on those 30's Chevys and get a head gasket that will work with both. Use the old one as a reference if you still have it. Hope that helps!
Mike | | |
