1 members (Phak1), 65 guests, and 1 robot.
Topics128,022
Posts1,055,361
Members48,420
#188135 08/21/2005 1:36 AM
Junior Member
Junior Member
can anyone tell me the size of my engine, its a 1935 chevy...and the closest headgasket people in my area have is a 1937 216 s-6. Thanks if anyone can help me
#188136 08/21/2005 5:02 AM
I think the 207 was used up through '36, but the first thing to do is confirm what motor you have. Its not unusual for a 70 year old vehicle to have been updated a time or two. Check the casting numbers against the info at inliners.org to be sure what you have.
#188137 08/21/2005 8:22 AM
My '34 had a 206 in it. Follow OldSubs advice and check the casting numbers though for sure. Also make sure that you have a '35 head and not some other year. I know from experience!! I bought a gasket set for my '34. No problem! Everything seemed to be the right. I had new babbit type bearings poured (yikes! that was big bucks) and I assembled the engine. I held the head gasket up to the block, no problem, all the bolt holes lined up and everything! I was home free! However, one thing I didn't know at the time (or even notice) was that Chevy had changed the head just slightly from '34 to '35 and the coolant holes on the head were slightly different. I torqued the head down and when I went to fill the radiator with coolant the first time, I was amazed at how much water and coolant the system took!! Suddenly there was coolant/water running out the exhaust pipe!
It turns out I had a '35 head on a '34 block and what I had done was fill up not only the radiator, but the crankcase and the cylinders of my brand new engine with coolant. I was fit to be tied!! :mad:
I guess what I'm saying is make sure you know what block AND what head you have on those 30's Chevys and get a head gasket that will work with both. Use the old one as a reference if you still have it. Hope that helps!
Mike
Mike
1958 Chevy 3200 Fleetside
1958 GMC 100 Wideside
Did you get free advice today? To donate to this site using PayPal is fast and EZ. Click here: http://www.stovebolt.com/office/thanks.html
