5 members (TUTS 59, Fannin, Phak1, Wheelie, chevyb), 284 guests, and 1 robot.
Topics128,084
Posts1,056,085
Members48,434
#188131 08/20/2005 8:26 PM
Hi all
Well, due to a serious load of rust and sediment in my gas tank (1951 Chev. 3100 series), I've pulled the tank and will have it professionally cleaned and sealed.
When I pulled the sending unit out, it was covered with rust and crud and the float had a hole in it. My tank uses the shut off valve on the bottom of the tank, and has a 1/4" pipe plug in the bottom - probably a drain, right? The sending unit looks exactly like one pictured in the Bowtie Bits catalog, part # AD-545-GTSU, supposedly for the 1954-1955 models. It had a capped off fitting on the top that lead to a tube running down near the bottom of the tank.
On the same page of the same catalog, they show a sending unit (part #AD-473-GTSU) for the 1947-1953 models that does NOT have this tube, just a float assembly on an arm.
Anyone have a suggestion as to which I should order for a replacement? Am I perhaps missing a return line or something, or is that tube supposed to be a vent line or something? Any help appreciated, I'll be ordering the parts on Monday.
fredstev
#188132 08/20/2005 9:21 PM
I am not an expert but I thought the one that you have is for the 54 and up,,, others may correct me,, hey shooper....help us out............Fred
Redryder pix
My Hotrod
#188133 08/20/2005 9:56 PM
I'm here..Sounds like someone put a 54 sending unit in it, and modified it to work..Just by luck, Joker52 sent me one that won't work on my 54 because mine sucks off the bottom of the tank, and comes out the sending unit at the top..I'd be happy to send you this one if you want to PM me with your address..Steve
