4 members (MNSmith, baldeagle, moparguy, KEVINSKI), 118 guests, and 1 robot.
Topics128,211
Posts1,057,468
Members48,471
I
Junior Member
Junior Member
I Offline
What is the hole in the roof of the cab for in my 63? It is toward the rear of the cab in the center with a rubber plug in it and goes into the inner space og the roof.
Thanks, Ivor
63 chevy short/fleet 292/4speed
under construction
Junior Member
Junior Member
I'm not sure , but I'm thinking that it was for an antenae or something. Someone probably did it years ago,I haven't seen any factory things like that. I very well could be wrong.
I'm older than my truck but it's smarter than me! 66 GMC 3/4 ton fleetside 283, turbo 400.
More than likely there was an antenna there.
Ivor,
It not stock what ever it was?
probally some PO thought an antanna would look good there, got any pictures?
1960 GMC 305A V-6 Gallery Page
Remember, the government cannot give --anything to anyone --that they have not first taken away from someone else.
BUY AMERICAN http://www.stillmadeinusa.com/index.html
Z
Z Offline
thats where i have my xm antenna.
V
V Offline
It could be for a spotlight also...
Gangster whites and straight pipes.....
I
Junior Member
Junior Member
I Offline
Thanks for all the input. I thought it was stock because it is a perfect hole with no chewed edges or anything. It is about 1" in diamerer. I'm not sure how you would feed a cable up into the space between the inner ceiling and outer roof. I';; try to get a pic tomarrow. I'm in the process of grinding all the paint off the cab so it is bare metal now. I ground the plug right out.
Thanks again
ivor
Thanks, Ivor
under construction
My high school job was installing and removing communication radios in police cars and commercial vehicles. In those days I put a lot of those rubber plugs in perfectly drilled holes in the tops of pickups. I also got good at sneak'n wires into small spaces.
Its almost certainly filling a hole where an antenna was once installed.
Anonymous
Unregistered
Anonymous
Unregistered
My 60 has the same. I just have never removed the plug. Interesting
I agree with the antennae....if it were a spotlight, it would have gone through the inner ceiling as well.
A roof spotlight was pretty common on farm trucks around here in the mid 60s. It was a pretty good way to check on irrigation, animals, etc, at night. Lots of fun for a kid, too. One could play spaceship, submarine, cops and robbers, almost anything while hanging on to the handle and rotating the beam up and down and aroound.
Don't guess the safety folks were too keen on having a metal handle hanging down in the middle of the truck...
Properly drilled antenna holes should look clean, and indistinguishable from the quality or look of a factory hole.
"jagged or "chewed" edges are usually a result of your 19 year old neighbor who is a "car radio expert" and uses spade bore/paddle bits or a hole saw intended for wood to punch all his holes.
A good communications installation tech can get a wire anywhere.. because ideal antenna placement isn't always where it's easiest to get a wire.. and unlike your local CATV or Satelite sub-contractor, just running the line down the side of the truck with romex staples isn't considered acceptable.
